The pressure should register:
ES 300: at idle 4.3 psi (29 kPa); at 3000 rpm 43-78 psi (294-539 kPa)
ES 330: at idle 4.3 psi (29 kPa); at 3000 rpm 36-78 psi (245-539 kPa)
IS 300: at idle 7 psi (49 kPa); at 3000 rpm 47 psi (324 kPa)
IS 250 and IS 350: at idle 11.6 psi (80 kPa); at 3000 rpm 55.5 psi (380 kPa)
LS 400: at idle 4.3 psi (29 kPa); at 3000 rpm 43-85 psi (294-588 kPa)
LS 430: at idle 4.2 psi (29 kPa); at 3000 rpm 43-85 psi (294-588 kPa)
Jakby komuś było potrzebne. pzdr!
Ciśnienie oleju dla Lexusów
- krzywydg
- Model Lexusa: GS430 MK I
Części Gs300/430
Części Gs300/430
