Personalizacja lexusa android/ios
Postprzez Miłosz » 6 mar 2016, o 14:44
Do personalizacji ustawień można użyć apki na androidzie. Nazywa się ona Carista , obsługuje modele :
IS (2014+, except IS-F and IS-C)
•RC (all, incl. RC-F)
•ES (2007+)
•GS (2013+)
•LS (2007+)
•RX (2010+)
•GX (2010)
•LX (2009+)
•NX (all)
•CT (all)
•HS (all)
•LFA (all)
Przykłady personalizacji dla IS 2014
Doors / Windows / Remote:
Blink turn signals when locking/unlocking with remote
YES / NO
Beep when locking/unlocking with remote
YES / NO
Volume of beep when locking/unocking with remote
OFF / 1 / 2 / 3 / 4 / 5 / 6 / MAX
Beep when opening/closing windows with remote
YES / NO
Warn when door can't be locked with remote because it's open
YES / NO
Warn when a window is still open when locking doors
YES / NO
Warn when sunroof is still open when locking doors
YES / NO
Panic function on remote
ENABLED / DISABLED
Open trunk lid with remote
SINGLE CLICK / DOUBLE CLICK / LONG PRESS / VERY LONG PRESS / DISABLED
Re-lock doors automatically if you unlock, but don't open a door
YES / NO
Re-lock doors automatically if you unlock, but don't open a door within…
30 SECONDS / 60 SECONDS / 120 SECONDS
Unlock doors via remote
DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / ALL DOORS ON 1ST PRESS
Unlock doors via physical key
Unlock doors via smart key (door handle button)
Auto-lock all doors
DISABLED / WHEN SHIFTING INTO GEAR / WHEN VEHICLE STARTS MOVING
Auto-unlock all doors
DISABLED / WHEN SHIFTING INTO PARK (P) / WHEN DRIVER'S DOOR IS OPENED
Unlock trunk when doors are unlocked
ON / OFF
After locking with smart key, allow re-opening within…
0.5 SECONDS / 1.5 SECONDS / 2.5 SECONDS / 5 SECONDS
Smart key location to start car
FRONT SEATS / ANYWHERE IN VEHICLE
Unlock trunk when smart key in range
YES / NO
Open windows and sunroof by holding key in door lock
ON / OFF
Close windows and sunroof by holding key in door lock
ON / OFF
Open windows and sunroof via long-press on remote
ON / OFF
Lower passenger-side mirror when in reverse gear (req. memory seats)
DEFAULT / USER-SPECIFIED
Instruments / Display / Dings:
Engine start indicator
ON / OFF
Remote low battery warning
ON / OFF
Lights:
Daytime running lights
ON / OFF
Coming-home lights duration
OFF / 30 SECONDS / 60 SECONDS / 90 SECONDS
Auto headlights activation threshold
DARKEST / DARKER / NORMAL / LIGHTER / LIGHTEST
Turn on marker lights when vehicle is unlocked via remote
ON / OFF
Instrument lights dimming sensitivity
Instrument lights restoring sensitivity
Dim interior lights after…
7 SECONDS / 15 SECONDS / 30 SECONDS
Turn on interior lights when you shut off engine
YES / NO
Turn on interior lights when you unlock doors
YES / NO
Turn on interior lights when smart key in range
YES / NO
Turn on interior door-handle & center console lights dimly (flood lights) when ignition is on and shifter is not in park (P)
YES / NO
Turn on exterior footlight (on side mirror) when smart key in range
YES / NO
Turn on exterior footlight (on side mirror) when doors unlocked via remote
YES / NO
Turn on exterior footlight (on side mirror) for…
OFF / 7 SECONDS / 15 SECONDS / 30 SECONDS
Interior lights linked to footlight
YES / NO
Interior light control
ENABLED / DISABLED
Exterior light control
ENABLED / DISABLED
Heater & A/C:
Temperature dial calibration
-2°C / -1°C / NORMAL / +1°C / +2°C
Ambient temperature calibration
-3°C / -2°C / -1°C / NORMAL / +1°C / +2°C / +3°C
A/C evaporator control
AUTOMATIC / MANUAL
A/C ECO mode
ENABLED / DISABLED
Auto-increase blower speed when front defroster is on
YES / NO
Auto-turn on A/C when AUTO button pressed (if needed)
YES / NO
Deactivate front defroster when AUTO button pressed
YES / NO
Also blow to feet in "face" mode
YES / NO
Seat heater mode
AUTOMATIC / MANUAL
Fan speed reaches its target…
SLOWLY / NORMALLY / FAST
Other:
Roll down rear shade when in reverse gear
YES / NO
Delay for rolling down rear shade when in reverse gear
IMMEDIATE / 0.7 SECONDS / 0.9 SECONDS / 1.2 SECONDS
Żeby to działało oczywiście potrzeba telefonu na androidzie ( ios ponoc tez się nada ) oraz moduł elm 327
https://play.google.com/store/apps/deta ... rista_site
Parę screenow
Obrazek
Obrazek
Obrazek
Miłosz
Dołączył(a): 29 lut 2016, o 14:59
Model Lexusa: Civic 2.2
Powrót do Zrób to sam
