Czy ktoś wie, czy można jakimiś trickami wyłączyć automatyczne zamykanie wszystkich drzwi po rozpoczęciu jazdy?
(GS300 MkIII AWD)
Tzn. czy istnieje podobny sposób jak np.przy wyłączeniu buzzera niezapiętych pasów.
wyłączenie zamykania drzwi
- Model Lexusa: RXI, II, GS i znów RX3
- margolll
- Model Lexusa: IS300 Sport
Re: wyłączenie zamykania drzwi
Chyba tylko w techstreamie takie cos wylaczysz
- Rici
- Administrator
- Model Lexusa: 3GS
Do wylaczenia opcji jest taka sama procedura tylko w pkt 3 trzymasz przycisk blokowania:
For the speed function (lock at 12mph instead of when shifting out of P), this is on Pg 38. The trick is, you have to CANCEL the shifting out of P in addition to SETTING the 12mph locking. In simpler terms, do this:
1. get in your car and close door
2. press start button twice, WITHOUT foot on brake pedal
3. press and hold LOCK on your door panel
4. count 1-one thousand, 2-one thousand, 3-one thousand, 4-one thousand, 5-one thousand
5. release immediately after 5-one thousand, doors will lock/unlock to confirm
6. turn off your car completely (press start button once without foot on pedal)
Then set for 12mph lock:
7. press start button twice, WITHOUT foot on brake pedal
8. put your foot on brake, and shift into N eutral
9. press and hold LOCK on your door panel
10. count 1-one thousand, 2-one thousand, 3-one thousand, 4-one thousand, 5-one thousand
11. release immediately after 5-one thousand, doors will lock/unlock to confirm
For the opening of all doors when touching any handle, this is on Pg 23. In simpler terms, do this:
1. stand outside your car
2. hold the key fob and press LOCK UNLOCK TRUNK all at the same time
3. count 1-one thousand, 2-one thousand, 3-one thousand, 4-one thousand, 5-one thousand
4. release immediately after 5-one thousand, the car will beep either 1x, 2x, 3x, or 4x
5. repeat this process until the car does 2 beeps to confirm the ALL door unlock function (each time you perform these steps, the settings change in order, so just keep going until you get the 2-beep confirmation)
tu masz więcej: http://www.clublexus.com/forums/gs-3rd- ... z3lcSai4eB
thanks!
Przyznam się, że w techstramie nie widzę takiej opcji. Znajomy mechanik z lexusa mówił, że oni takie rzeczy programują w ich serwisowym programie. Ale to oczywiście kosztuje kilka kzł.margolll pisze:Chyba tylko w techstreamie takie cos wylaczysz
Robię jak napisane i...
... W tym miejscu nie ma żadnej reakcji auta
Jeśli przycisk lock nacisnę dopiero po wyświetleniu "complete".
Faltycznie, jeśli nacisnę na 5 s przycisk lock od razu po drugim kliknięciu przycisku stacyjki, auto potwierdza "zamykając i otwierając drzwi"
tyle, że...
ustawienia się nie zmieniają ani w kwesti zamykania po ruszeniu wybierakiem, ani przy próbie przejścia na zamykanie 12mph (w pozycji N).
Jakiś oporny jest mój samochód, albo ja...
tyle, że...
- Model Lexusa: Lexus
Najlepiej zrobić to za pomoca TIS. Można przy okazji inne rzeczy ustawić. Mieszkam na Mokotowie. Jak będziesz któregoś wieczora w okolicy to daj znać wcześniej.
